Hi, first post here. I am looking for a 48v dc light switch solution for our cabin. I know leviton (Model #: 12021-2I) is dc rated for 24v at 3 amps. I know that the the reason NOT to use a regular switch is because of dc arcing. I want to run off the batteries so I can turn the inverter off at night to save on battery draw. I can't find a 48v rated light switch so I can only think of two options.
1. Run a 48v to 24v dc converter and run the lights on 24 volts.
2. Use a SSR-40DD solid state relay that turns on with 12-24 volts to use the leviton switch and still provide 48v to the lights. I am already using a 48 to 12 volt dc converter (60 amp) to run my dc refrigerator.
Am I overlooking a better option?
Thanks, Dan
Thanks, Dan
