Not necessarily. It may clip for lets say an hour.
It will clip for close to 2.5 hours, maybe longer if sun appeared at 11 am and still have good sun at 2 pm.
What about the rest of the day when it's producing more than what was lost?
You don't peak output the rest of the day as the sun has moved past peak.
You get the same yield from X number of panels overpaneling a SCC or not. This morning was a prime example, each panel was producing the maximum it could from the available sunlight.
My array doesn't get bigger or smaller, it stays the same size day after day. Unless somebody has been sneaking around and taking panels away when I'm not looking.
THAT is what you fail acknowledge and you think your "one size fits all" approach is the only one that is correct.
I'm giving a completely different approach here. Large battery bank to capture as much production as possible and using enough SCC's to capture any yield. If you are close to max rating for charging the bank, then you need more storage. If grid tied, it wouldn't make any sense to overpanel an inverter as the grid is an endless battery. Put the maximum amount of power you can onto the grid at any given time so it can be pulled off the grid later.
Actually you did when you said overpanneling (adding more panels) won't produce more than underpaneling.
Overpaneling will only produce more by adding more panels. That is the strawman argument.
I could add the same number of panels with another SCC and outproduce the overpaneled SCC any day.
You fail to grasp that concept. Adding more panels in both cases will increase production over X number of panels. The strawman argument is always, well I have more panels because I overpaneled. It is ludicrous.
If add more panels with underpaneling the
SCC's and enough SCC to cover it, it will produce more.
All you need is a load to capture the excess into something useable. Lead acid suffered from needing an absorption charge to prevent sulfation and internal resistance would increase as SOC increased. This required long periods of production thru the day.
LFP doesn't suffer from the need to extend charging hours over long periods of time, take every watt you can get at each second and shove it into the LFP. It will take it.
One member tried claiming it would be excessive charge rate. If done correctly the way it should be done with LFP, you want at least a 5:1 ratio of battery capacity to PV max output. How is that anywhere close to hitting C rate of the battery bank? One could even go with a lower ratio of battery to PV, as long as a manufacturer C rate is not exceeded. In his example, he showed a 400Ah battery cell with a C rate of C3 which would be 1200A. In order to exceed the C rate would take PV of over 60Kw. I'd like to see that array.
Unless you were somehow only talking about peak sun when clipping may occur. But nobody here would think that.
4 hours of peak sun and let's say 4 400W panels on their own SCC. Do the math on how many more Kwh it produces compared to an array that is overpaneled and clipping the 400W per string during those 4 hours.
It isn't only that aspect, I still get the yield the rest of the day. I have yet to see an array that changes the number of panels depending on weather conditions or the time of day.
You install X number of panels that fit the mounts. Those panels have a yield potential = to the amount of sunlight hitting the panels each day.
