I’m running a Multiplus 12/3000/120 connected to 3 diy 280Ah 12v LiFePO4 batteries, each with a Daly 150 BMS. Batteries run in series to a lynx distributor, then to the inverter. 4/0 wires the whole way. The inverter does fine with light loads, but if I put any decent load on it, I get a huge voltage drop and the inverter cycles off. For example, if I put an 1800W induction cooktop on, even at partial power, the voltage at the Multiplus drops to 10.2 v and the inverter cycles off. Even if the Dalys are overrated, it seems like I should be able to pull 150A off the 3 batteries no problem (no other load on the batteries).
I’m not certain where to look for a failure point for or diagnostic steps. Any advice is appreciated. In case it’s helpful, I’ve attached the BMS settings. Thanks!
