Prefersdirt
- Sep 28, 2019
- 377
So there will be different posts coming from me as we are getting a new place and I will be taking it almost entirely off grid. A separate post will come about inverter recommendations.
Batteries. This is for a 48V system to provide up to 200A service (to match the grid input).
DIY has costs running like this: (Still waiting on a couple of quotes for cells – this is based on one).
Total setup (per battery)
cost: $2294.28 + a few hours of my time.
Capacity = 230 aH / 11 kWh
Prebuilt:
I have two issues with DIY batteries. There is zero communication between the inverter(s) and the battery(ies). None. This makes shutdown at low voltage challenging. I love the idea of being able to tell it “Shut down at X%”.
The other issue seems to be multiple batteries in parallel going slightly out of sync in terms of state of charge. The two I have now were that way for a while. (I need to double check them but am not near them right now).
Just wondering what I am missing in these calculations? If I were starting from scratch, I would love the prebuilt more. But money is a major concern and I can DIY.
Thanks
David
16 230aH cells at $127.58ea for a total of $2041.28
BMS from Overkill solar at $153
Miscellaneous for the box - $100.
Prebuilt:
Signature solar – EG4 - $1500 100AH = 4.8kWh
BuyCheapSolar – $2900 10kWh
Watts247 – PowerUp $1700 - 5.1 kWh -
Thanks
David
