acor
Hello,
I am new to everything. Electrical and solar.
I set up the eg4 6500 inverter with the 48v battery into my rv. Now the problem that I'm having is that the battery is only allowing the inverter to work or the 12v system to work, but not both. If both are connected then the battery turns on the alarm and shuts down. I am still trouble shooting to see what it could be.
Solar panels are still not connected.
I'm trying to see if anyone had a similar experience.
Quick note. The RV had a 50watt solar panel and a 1 x 12 volt battery connected it and it RV worked fine when I connected to the grid.
