Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,682
I've read on this being a no no. Is a steel washer ok on top of the lug in between the bolt head and lug, but not between the lug and bussbar?
Steel (preferably stainless) on top is fine. Negligible current through bolt.
I have 4 batteries in parallel, none is series. One inverter. I think I understand you by saying halving the current as in put 2 lugs(from batteries) on either end of each bussbar with inverter loads going to the middle of the bussbars?
Yes, that would be an improvement. Maybe not enough if your busbar can't even handle half the current.
What if you just stacked all lugs and ran a bolt through? Battery, battery, inverter battery battery.
Now do that with the bolt threaded into your brass busbar (all lugs on one bolt in one hole). Then you can attach leads from charge controllers, presumably much less current than inverter.
That makes a lot of sense, thanks for clarifying what the issue is with stacking multiple lugs. Before now I never could find a reason not to, I assumed that it would be less resistance because current would be traveling through less conductor. But in you example, I can see how resistance can go up.
I like the piano string look haha, but I will have to do some rearranging to fit my new bus bars and mrbf fuses. Sucks I thought I knew what I was doing and chopped up all my 4/0 wire already.
Well, looks like these buss bars will only handle 2 leads from my charge controllers. Grrrr
General rule of thumb is don't stack lugs, if you must stack no more than 2 on each screw.
Rules were made to be broken, and thumbs get sore when they're in the way.
A fat copper busbar would be nice, though.
Here's mine:
DIY Bus Bar
Im looking to make my own DIY Bus Bar that can pull 1000amps as buying one is expensive. Im looking to use it to connect a large battery banks. Can this be dune with supplies from hardware stores? Anyone know a good way to make on and what parts to use? The only one I can buy is this...
diysolarforum.com
There are two fuses for positive on top. Underneath, busbar with one battery in middle, four inverters attached top/bottom of busbar to either side of battery connection.
