That sure is the truth, when I have it spit out simple code it takes time to debug it. The github AI of course does better with code but is more complicated to get setup.
Ok, I lead chatgpt around by the nose... and the earlier issues were due to converting from metric to imperial units of measure then mixing the two later. The mixture is it was using the area in mm mixed with the ampacity in inches and not converting along the way. This time I checked the steps and verified the unit conversion and formulas and only had it do the basic explaination -
YMMV!
Summary is this - LiTime seems to have rated their bars as if they were copper instead of brass -- details below but here is the chart showing what reality is. I would bet the engineer designed them as copper and some bean counter in production decided to make a quick buck by letting the mfg of the bars produce them in brass as long as they are coated in copper before the nickel so they look like copper to the unwary.
The liTime bars are 200amps while the cheaper ones you have are only 69amps.
Here's the summarized data in a chart, showing the estimated ampacity ranges for different materials and bar sizes:
Material | Ampacity (25.5x6.5 mm) | Ampacity (16x3.5 mm) |
Cheap Brass | 51.4-102.8 A | 17.4-34.7 A |
Brass for Bus Bars | 154.2-205.6 A | 52.1-69.4 A |
Copper | 257.0-308.4 A | 86.8-104.2 A |
You
How do I calculate the ampacity of buss bars made from brass
ChatGPT
Calculating the ampacity of bus bars made from brass involves several considerations. Ampacity refers to the maximum amount of electrical current a conductor can carry before its temperature exceeds a specific threshold. Here's a basic guide on how to calculate it:
- Material Properties: Brass is an alloy primarily composed of copper and zinc. The ampacity depends on the material's electrical conductivity and temperature rating. Brass generally has lower conductivity than pure copper, so it will have a lower ampacity for the same size.
- Cross-Sectional Area: The ampacity is directly proportional to the cross-sectional area of the bus bar. You need to measure or know the thickness and width of the bus bar to calculate its area. Area �A is calculated as �=width×thicknessA=width×thickness.
- Current Density: The current density (�J) is the amount of current per unit area the material can carry. This value varies for different materials and depends on the operating temperature. For brass, this value is typically lower than for copper. You might need to refer to engineering tables or standards for the specific current density value for brass.
- Calculate Ampacity: Once you have the current density (�J) and the area (�A), you can calculate the ampacity (�I) using the formula:�=�×�I=J×AWhere �I is the current in amperes, �J is the current density in amperes per square inch (or other units of area), and �A is the area in square inches (or other units of area).
- Consider Temperature Rise and Derating Factors: The ampacity is also influenced by the temperature rise in the bus bar due to the resistance and current flow. Higher temperatures may require a derating of the ampacity. Environmental conditions, such as the presence of other heat sources or cooling factors, also impact this.
- Safety and Standards Compliance: Ensure that your calculations comply with relevant electrical codes and standards. These standards may provide specific guidelines or tables for calculating ampacity for different materials and sizes.
- Consulting References: It's always a good practice to consult technical handbooks, datasheets, or an electrical engineer for precise calculations, especially for materials like brass, which are less standard than copper or aluminum for electrical conductors.
You
Assuming the bars are 25.5x6.5mm give me a formula for calculating the ampacity
ChatGPT
To calculate the ampacity of brass bus bars with dimensions of 25.5 mm x 6.5 mm, you'll need to follow these steps:
- Calculate the Cross-Sectional Area: First, you need to calculate the cross-sectional area of the bus bar. The area �A is given by the formula �=width×thicknessA=width×thickness. In your case, the width is 25.5 mm and the thickness is 6.5 mm.
- Convert Dimensions to Consistent Units: If the current density (�J) you have is in amperes per square inch (which is common), you'll need to convert the dimensions from millimeters to inches. There are 25.4 millimeters in an inch.
- Current Density (�J): This is a material-specific value indicating the amount of current per unit area that can be carried safely. You'll need to find the current density for brass, which will be in amperes per square inch or another unit of area. This value can vary based on the specific alloy and conditions, so it's important to find accurate data for the brass you're using.
- Calculate Ampacity (�I): The ampacity can be calculated using the formula �=�×�I=J×A, where �I is the current in amperes, �J is the current density in amperes per square inch, and �A is the area in square inches.
Let's put this into a formula:
�=width (mm)×thickness (mm)(25.4)2A=(25.4)2width (mm)×thickness (mm) (to get the area in square inches)�=�×�I=J×A
Given the dimensions 25.5 mm x 6.5 mm, let's calculate the area in square inches.
The cross-sectional area of the brass bus bars with dimensions 25.5 mm x 6.5 mm is approximately 0.257 square inches.
Now, to calculate the ampacity (�I), you would use the formula:
�=�×�I=J×A
Where:
- �I is the ampacity in amperes.
- �J is the current density for brass, in amperes per square inch.
- �A is the area in square inches, which we've calculated to be approximately 0.257.
You'll need to find or know the current density (�J) for brass to complete this calculation. Once you have that value, simply multiply it by 0.257 to find the ampacity.
You
What is the J of both cheap brass and brass for buss bars
ChatGPT
The current density (J) for brass can vary significantly based on the specific alloy and its composition, particularly in a material like brass which is an alloy of copper and zinc. The proportions of these metals can greatly influence its electrical properties.
- Cheap Brass: This type of brass typically has a higher zinc content and may include other elements to reduce costs. Its electrical conductivity is usually lower than that of high-quality brass, leading to a lower current density. Unfortunately, specific current density values for "cheap brass" can be quite variable and are not standardized. You may need to refer to the manufacturer's datasheet or conduct tests to determine the precise value.
- Brass for Bus Bars: High-quality brass used for electrical applications, like bus bars, typically has a higher copper content, which improves its conductivity. This type of brass would have a higher current density than cheaper alternatives. However, even for this quality of brass, the current density can vary. It's generally lower than that of pure copper, which has a current density of about 1000-1200 A/in² under typical conditions.
For accurate and safe calculations, it's essential to get the exact current density value from the manufacturer or from a reliable engineering database. The current density value is crucial for calculating the ampacity, and using an incorrect value could lead to unsafe conditions, such as overheating.
If you can't find specific values for the brass you're using, a conservative approach would be to use a lower estimated current density to ensure safety. For precise and critical applications, it's always recommended to consult with a material scientist or an electrical engineer.
You
make a guess at both values
ChatGPT
When estimating the current density (J) for brass, especially without specific alloy details, it's important to err on the side of caution. Here's a conservative estimate for both types of brass:
- Cheap Brass: Given that cheaper brass alloys have higher zinc content and potentially other elements that reduce electrical conductivity, the current density would be significantly lower than that of pure copper or high-quality brass. A conservative estimate might be around 200 to 400 A/in². This estimation accounts for the lower conductivity due to higher zinc content and possible impurities.
- Brass for Bus Bars: High-quality brass designed for electrical applications like bus bars will have a higher copper content, thus better conductivity. However, it still won't match the conductivity of pure copper. A reasonable estimate for this type of brass might be around 600 to 800 A/in². This range considers the improved conductivity due to a higher copper content while still being significantly lower than pure copper.
Remember, these are very rough estimates and should be used with caution. For actual applications, especially where safety and efficiency are concerned, it's crucial to use specific data provided by the material manufacturer or verified through testing.
