Merlmabase
- Jan 6, 2020
- 17
Hi folks. Just received my 280h EVE cells, Multiplus 24/3000/70-50, and Overkill BMS in the last couple of weeks. Starting to configure everything and run through a couple of charge cycles just to get the hang of things. No solar panels/SCC yet, waiting until I can start working on converting a vehicle in the spring.
I have a question about over-discharge protection. I know on the charging side, you should have parameters set at the SCC and inverter/charger, with BMS cut-off being the last line of defense.
Does the same apply for discharging? I can set inverter parameters for a low-voltage cut-off, but for my DC loads there's nothing but the BMS protecting the cells from over-discharge. Am I missing something? Should there be another component monitoring discharge and able to cut loads at a given voltage? I also have that cheap shunt/monitor that Will likes, should that play a role?
Very grateful for your help.
