i got the same problem with the 280Ah xuba LFP.
i got two that are raising voltage a lot faster than the others.
these batteries have unusual specs.
they are running fine fully charged at 3.3V (i charged at 3.3 then discharged over 250W/24H, and get the full capacity)
i have 2 cells going at 3.7 very fast, while all the other seems to stay at 3.4 max
first time , i charged without BMS and the 2 cells goes very high (over 3.8 while others were at 3.3)
Then after discharging , i installed the BMS, all were at 3.0 and recharged.
Again all were at 3.3/3.4 but the 2 same ones goes to 3.6.
So these Xuba batteries are fine, but the curve is very flat (you have full capacity between 3.4 and 3.0)
if you order some, better to take some spare cells. Will do next time, as i plan to build a second 8s pack.
