I am designing a system to DIY for my house incorporating solar, batteries, and a hybrid inverter (EG4 18kPV is what I've spec'd right now).
My utility feed comes into my basement, which is also where I want to locate the 18kPV. Per the manual I need an outdoor fused disconnect between the grid feed and the 18kPV grid input; the location for my disconnect is 75' of wire away, and the hot leads call for 3/0 AWG at that distance.
How wrong would it be to only run L1 and L2 to the disconnect switch, and just keep the Neutral and Ground in the basement running between the panel and 18kPV to save wire and effort? The neutral just runs through a busbar at the disconnect switch anyway, and I could ground the disconnect panel itself since it'd already be outside.
Like I said it would just be to save money on wire and installation effort, and it makes sense in my head but still feels kinda wrong.
So would this be dangerous, and/or would it pass code?
