S Davis
- Sep 25, 2021
- 633
A forum member ask me to post about an air to water heat pump installation I completed recently.
I installed the radiant floor heating system about 20 years ago and the customer just installed Solar and wanted to get away from propane fuel.
The old boiler is staying intact to heat domestic hot water and could be used as backup if necessary. The new system uses a 5 ton Bosch BOVA heat pump outdoor unit and a Noreaire indoor unit with the integrated electric backup, the system heats a buffer tank to supply heat to the radiant floor system.
It heated in heat pump only mode through the 10 degree weather we jus had.
