I'm slowly building up another battery and I thought to post the plan in hope of getting some feedback. Can anyone see potential issues etc.
There will be 3 batteries in parallel, but let's focus on just one. It is a 16s configuration of EVE MB31 cells sitting on top of a thick fr4 like isolating sheet on a shelf.
This battery is using compression as all my batteries are. Cells will be sitting in "normal" position. Fr4 separators will be on all sides. I'm still debating if I should use neoprene in addition to fr4 (my neoprene compresses by about half at 12psi, then resists a lot more).
Pack compression will be provided by 10mm thick steel plates, 6mm threaded rods and disc springs.
Cells will be connected in a "snake" configuration with DIY non flexible bus bars.Here is a drawing from the top.
![20240719_143511.jpg 20240719_143511.jpg](https://diysolarforum.com/data/attachments/229/229710-6d9766e67cb32624a7501bf41a6ccb87.jpg)
I've already cut the steel plates and I drilled the holes for the rods. The reason why we have 8 cells two rods then 8 cells again is very limited side to side clearance.
I already have heltec 200A bmses for these.
Any comments? Ideas? WTFs?
