Hello all,
i am building a new system from scratch. 24 volt, probably using 8 x 280AH EVE cells or similar, rated to around 200 amps. I’m trying to decide which BMS to use.
I am not really wanting to use an app to monitor the battery, I’d rather extract basic status information using an Arduino or similar device and display it on a small LCD, ideally using Bluetooth, but wired serial is ok if I have to go that way.
Can anyone recommend a BMS that is simple to integrate in this way?
Thank you,
Matt
Thank you,
Matt
