Can you share where you're getting the enhanced HA integration from?Yes, I bought the solar assistant to work with HA but it’s useless because I can’t do any automation, but I searched around and found a LuX python dev. Now im able to control my inverter through HA…
Check the On-grid and off-grid cut off..
The 12k inverter, will not pull below 10% of the battery if it’s connected to the grid unless use Volt instead of SOC..
can you take a pic on your battery settings on the inverter?
Attached is my settings screens from the unit. Whatever communication that is happening is clearly inadequate because it thinks the battery is at 0C and the cells are at 0mv.
When I tried what you talked about above (lead acid, 750AH, save, back to lithium on bat type 14) I get no communication when plugged into either the CAN or RS485 port on my battery. No change in behavior with inverter reboot.
Would love to get communication working. Just not sure what to try next. Ethernet cable is fine (I have a tester)
