GridWorks Green Solar
Solar Innovator
Ugly vent intake works, back to 24/7 running the mini split on seamless secondary power if desired.
Lots of options for the future, Best shot at making it look pretty and less ducting is swap the inverter down one shelf and putting the display and secondary ISO on the top shelf, ventilator with small amount of duct work stays on the very top of the cabinet. Would like to be able close the cabinet door completely when finished.?
Sorry still working out the details but if it helps you get it right the first time it is all worth the effort, Love the project system will not stop till multiple working examples exist, will go to the extreme to help you see the power?
**(One free new FETs 40N65 power board and case fully functional Inverter unit hand delivered to one lucky person that will assist in me testing the project system.)
**(PM me to claim the pure sine inverter and assistance, open offer till I say otherwise, will work with you on the timing and location to get a working example.) (Contenitial US only)
**(To have working need 9-16-27 project array PV array panels working 180VDC! and a 15-16 amp main ISO for safety add one more solar panel if off grid. Needs to be car accessible please)
First picture:
The more I think about the rolling cart version of the power system the better I like it, 20 inches tall, 16 inches accoss and 12 inches deep should work nicely.
Like a gas generator but no gas and nearly silent operation, add one of the newest Li-Ion battery units for the home run, I am telling you people need this power unit, money to be made from building exactly what is shown here.
Look again
**Just finished upgrading a new factory board with the hard to kill New 40N65 MOSFETs, New 2000-3000 watt pure sine choke. Bench tested nice pure sine wave power 60Hz Just needs installed in a metal case.
**Fully adjusted for max power meets all project requirements.
Your prize power board is ready ??
**Prize board is now mounted between two serious heat sinks in a metal inverter case with fans, fully isolated needs the silicone to set for one day before soldering on the wires and loading it up on a bench test. Not the prettiest of cases but already has the mods needed for the power board.
**Willing to wait for you to be ready as long as you are serious about the array and 15Amp ISO,About $850 for 9 standard solar PV panels and $400 to $500 for a 15Amp ISO transformer.
**My medical grade 16Amp transformer was purchased used on Ebay for $200 (They never go bad) used or mixed panels work fine target DC voltage is 180 ! voltage in full sun, be careful.
Previous factory board from that case still running after 4 years of service in line for the 40N65 MOSFET upgrade and main backup board for the main project system.
First picture:
Look again
