The new MeanWell NPB-450-12 charger arrived, yes it's a 25A version. I decided since the vast majority of all my charging is from solar panels, a little bump when plugged in, or when generator runs, was enough. Besides, it's about $75 less than the 750/45W version.
It's a very nice compact unit, easy to install, is very quiet - I can't even hear it running under the sofa, and charges perfectly. 2-stage charging starts out in bulk/boost, which is constant current, set for 'gel battery' with dipswitches at 14.0 volts. When the battery gets close to the boost voltage it tapers current - CV - and terminates charge when current gets to about 10 watts.
I have sent them a tech support question on whether the unit re-boosts at some system voltage point, and will follow up. My inclination is that it does not - it has to be power-cycled to restart the charge cycle.
The manual also says charge termination is when current reaches 10% of charge capacity, which is 450 watts or 25A, so I would expect that at about 40W or 2A. But it's about a quarter to a third of that. I've asked for clarification on that as well.
I had 4awg leads for the old Powermax, so I removed those and made up new 10awg leads (spec recommended), and replaced the 80A connection to bus fuse with a 40A I had on hand. I may try to find a 30, it's ANL, but it's probly fine. The terminal posts on this size charger are pretty small - they are like 5 or 6mm screw contacts, so a forked terminal was appropriate. At full charge everything is cool, and the fan runs on full but is very quiet.
I'm thrilled. For anyone that would need more juice, or has a bigger battery, the 750 model with 45A of charging would be recommended. Overall, and so far, this one is a slam-dunk winner.
