Thank you all.. I’m in the Florida keys about 20 miles from Key West. I have 12 485w panels set in 3 arrays of four panels, each connected to a different moot, 3 LL4 batteries connected to a pair of 6000XP units through big buss bars. I’m running a 18000btu dual head mini, soon to be 2, and most of the other 120v circuits in the house. Each night we use about 50% of battery capacity. The temps, I guess, are being reported to the SA by the inverters and to them from the BMS. I will recheck the connections which were torquedto spec. The units are degrees F. As I type this at 0230, the outside temp is 78, the battery is showing 85, inverter 84 and I’m drawing 400W. Here is a shot of PV power vs utilization (watts) for the same period. The battery reaches 100% pretty quickly in the morning, usually by 1130. Max charge urgent is currently set to 125A. Perhaps this i too high. Should I turn that down and stretch the charge over a longer period? Thanks again.
