Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,660
this is what mpp solar say...
Your LR4-72HPH-445M solar panel size (STC): 445W, 49.1 VOC, 11.53 ISC
It’s no problem to use 2 panels in series, the PV input: 890W, 98.2 VOC, 11.53 ISC.
What they said is true only if your ambient temperature never drops below 25C.
In this case, if you listen to the manufacturer it could kill the inverter.
While their engineers probably know what they are doing, the front-line people apparently can read some values on a data sheet and do simple math, but are unaware of normal issues using PV panels.
According to the data sheet I find for your panel:
ENF Ltd.
LONGi Solar Technology Co., Ltd. Solar Panel Series Hi-MO 4m LR4-72HPH 445-465M. Detailed profile including pictures, certification details and manufacturer PDF
www.enfsolar.com
Voc will increase 0.27% for each degree below 25C.
For my San Jose location, to be conservative I assume -15C which is record cold or a bit below. So 40 x 0.27%
Using that assumption, two panels in series would reach 109V
Gnubie noted that using the two panels in parallel rather than series would work for 2kVA model MPPT, staying above its minimum 30V input. So that is the way to go.
