cmack
I have 2 identical PV arrays connected to 2 different inputs on my SA 15k. Both arrays are connected to the same RSD transmitter.
This morning array 1 stayed at 6v while array 2 climbed quickly to 280v (as expected). This is the 2nd time this has happened in about 2 weeks.
A quick reset of the RSD transmitter solved the problem, as you can see in the screenshot around 8:45 AM.
Has anyone experienced something like this before? Any idea why?
EDIT: The last time this happened, I reset the PV breaker and that solved the problem. I did not touch the RSD in that case.
