myusername134
Looking at having roughly a 5 KWh battery bank (lithium) using roughly 70-80% (~3.3 KWh) of this per day. Main usage would be: laptop, chest freezer + fridge. Id like to be able to replenish this usage every day (location Tennessee), so to charge roughly ~3.3 KWh assuming ~4 hours of direct sunlight and ~70% efficiency of the panels im looking at atleast 1200 watt array, or 12 100w panels ( https://www.amazon.com/dp/B09V4ZDJTJ ).
1. I could have a series/parallel setup with two rows of 6 panels (12 panels total). So one row of 6 panels would generate 600w, then both rows connected in parallel would make 1200w. Heres where I get confused, im learning the rated "12v" on the panels is not correct, and its actually generating 24.3v called the "Open-Circuit Voltage", during colder temperate this increases (IDK by how much), im going to assume as much as 30v. So 6 panels would generate 145.8v up to 180v during cold weather at 4.91a. This already exceeds the max voltage for many of the solar charge controllers. With the two rows in series/parallel it would be ~145.8v at 9.82 amps. I couldnt do anymore rows in parallel because the panels fuse rating is "15a" ( is this correct?), however it is in 12AWG wire which is 25a max. Can someone shed some light on how this works?
2. What sort of lithium battery setup should I have and in what voltage? I could get something like this ( www.amazon.com/dp/B0B96WR27C/ ) which is 48v at 100AH. Or should I get smaller batteries to scale more easily? I'll likley desire more then 5 KWh to have battery reserve during bad weather and increase the amount of panels.
Any other advice / suggested products I should get would be apprecaited.
