Hi - Has anyone heard of Nuvation? After a quick read I envision this is what a polished Chargery BMS should be. ;-) @Will Prowse
I stumbled across this BMS system while reviewing IronEdison LifePO4 product line. They use a combination of this BMS along with the active balancer QNBBM to manage their LifePO4 line (see picture): https://ironedison.com/48-volt-lithium-battery-for-solar
For the price it looks somewhat interesting given the commercial use and the amount of features and expandability. My first thought is that since this is being leveraged by larger installs it maybe more proven and robust than the current options out there that I am reviewing, SmartBMS, ANT, Chargery, 123BMS. I have not had a chance to dig through all the specs. yet but I thought I'd share the finding.
Low voltage BMS offering: https://www.nuvationenergy.com/battery-management-systems/low-voltage-bms
Technical Specs.: https://www.nuvationenergy.com/site...Nuvation-Energy-Low-Voltage-BMS-Datasheet.pdf
+ I like the fact it looks like you can add onto the BMS and monitor a separate battery bank.
Thanks
Thanks
