I believe that Luyuan Tech on Alibaba has sent cells to members in NZ. The Shipping Guestimator on Baba "sux" you need to talk with Amy Wan in their chat / messenger app.
Shenzhen Luyuan Technology Co., Ltd. - Lifepo4 battery, LTO battery (alibaba.com) Just because a vendor site does not indicate NZ, check with the reps to make sure. We KNOW Good Vendors as well as BAD Vendors here, tons of experience, so search the forum if in doubt on any vendor.
Your descriptions in the thread are indicative of Unmatched / Unbalanced cells misbehaving in your existing battery packs. This is not unusual for that type of "Bulk Commodity cells". Active Balancers can mitigate some minor deviations but no balancer or BMS can "fix" bad or weak cells. I am also unaware of any JBD BMS with built-in Active Balancing, a few have Passive Balancing.
Li-Ion BMS - White Paper - Dissipative vs. nondissipative balancing (a.k.a.: Passive vs. Active balancing) It may be possible to extract the cells & BMS
(disconnect BMS Harness from BMS prior to disconnecting any other wires) and perform a Top Balance on the cells and repack them using the same BMS. NOTE, it is VERY easy to fry a BMS, so care & caution.
Ideally for 24V System, you want to do Straight 8S battery packs, each with a BMS & Fuse rated to the max anticipated load & charge that you will be using. Each battery pack then set into parallel to equally share the load & charge potentials. If packs are matched in AH Capacity this all plays out fairly evenly. If you have a 150AH Battery & 250AH battery in the bank, that is FINE (no lead-isms here) but you will see a difference in charge & discharge handling relative to the pack capacity which is also fine. One gotcha that folks must pay attention to though, is once the 150 hit's Low or High Volt disconnect, the 250 will keep going. This is where a key point has to be accounted for, each battery BMS should be able to handle the FULL Load/Charge potential as a standalone battery. This is also Failsafe/Fallback protection in case one or the other decides to cut off.
Also have a look at this doc, starting on page 17 about setting up batteries properly in parallel within a bank.
VICTRON Wiring-Unlimited-EN.pdf
Have a good look at the links in my signature, there is info in there you will want and spend a heap of time looking for.
