I need help in designing an off-grid system, here are the energy requirements;
- 12 vdc water pump (about 50 watts) https://www.nemopumps.com/
- Computers- (about 500 watts 120 VAC) (wouldn't be running all of the time- only a few hours a day)
- A few led lights (about 50 watts 120 VAC) (only when needed, which is a variable)
What I think I need, in basics are- PV panels, charge controller, inverter
System must be run off of lead-acid battery(s)
What system components would you recommend to satisfy the energy needed above?
Are there any other components I should add?
Thank you,
Peter
Thank you,
Peter
