ericfx1984
- Oct 10, 2021
- 741
Ok. So I am planning out my solar system...
So far I have the following:
- MPP Solar LVX6048 (6.6 kw low frequency inverter, with 125a MPPT and plugin charger, 120v/240v)
- 40x Santan Solar 250w poly panels
-EP Ever 60a MPPT (actually have 3 of these)
- 16x 280 ah Eve Cells
- 16x 304 ah Eve cells
- 2x, 200a 16s BMS (JBD?)
I figured that I could run lights and "Primary" loads off the above listed inverter
I could put about 7000w worth of panels on the LVX 6048, and the rest on an EP Ever... this should give me some redundancy, while also allowing me some additional bulk charging ability
The above listed inverter will serve my needs unless its summer time... SO I figured I could add a few smaller inverter, 3000-5000w china high frequency, these could run mini splits and maybe other loads... basically, inverter "ZONES" However, I need a way to have a master shutoff... maybe a relay coming of the main inverter and disconnects when/if the main inverter shuts down? Any ideas for this?
Or would it just make more sense to add a second LVX6048? They are stackable... AND this would eliminate the need for the EP Ever 60 amp MPPT... additionally each non-paralleled inverter would need it's own (AC) line ran to the house... as well as a separate breaker box? that could get weird
All the gear will be located in a 5x7 shed... I plan to insulated it quite well, add some kind of air conditioner maybe a small inverter window unit? I think a 9000 btu mini split will be over sized for this shed
Finally I plan to add 1 or 2 more 16s batteries
