Hello, I'm new to this forum! I found this forum watching Will Prowse videos. I am looking for advice or suggestions for an off-grid woodshop I am constructing in northern CA.
The woodshop will have no ability to connect with the grid. I’m trying to build an affordable system, with the ability to upgrade later with more batteries, panels and maybe another inverter and a second battery monitor.
The workshop will include the following tools:
3 hp tablesaw 220V
Festtool Chopsaw
20 inch bandsaw 220v
8 inch delta jointer
15 inch 220V Powermatic planer 220V
Several 110V Sanders and various power tools
It seems like a lot, but the important part to understand is that I only use one tool at a time. I addition, I use a lot of hand tools. This translates to roughly a current commercial electric bill for the Los Angeles area of about $60 a month, or approximately 248kwh per month.
I are planning on the following design:
(8) - 24 volt Battleborn batteries.
(1) AIMS Power PICOGLF60W24V240VS24 Vols Pure Sine 6000 Watt low Frequency. 110/220Vac Inverter.
(1) Solar charge Controller. MPPT 150 /35
(1) Battery Protect BP/220
(1) AiLi Battery Monitor 8-100V,0-350A
(1) DC 6.5-100V 0-100A LCD
(1) DC 5-120V 100A Amp Meter.
(1) Battery capacity monitor.
(1) Circuit Breaker For Solar charger
Multiple Bus Bars
Multiple Fuses and Holders
(1) Cell Balancer
Main fuse for battery bank to inverter
Automatic transfer switch (I believe is built into the inverter).
4/0 AWG Gauge 3/8in Lugs.
24V > 12V Converter to run LED lights
Common port 8S LifePO4 BMS
10 x Solar panels run in parallel (not sure which ones to get yet. Any advice is appreciated) in sets of two, then in series.
20kW light power deisel generator with autostart
24 volt 200 amp relay
I would appreciate any input or any suggestions on this system. Thank you.
3 hp tablesaw 220V
Festtool Chopsaw
Multiple Bus Bars
(1) Cell Balancer
