Growinupinfl
Hello to all,
This is my 1st post and I feel I've only achieved Newbie status through watching Will's videos. I found some Q&A on here comparing different size panels, but doesn't seem to answer some of mine. Just like everyone i want a capable 1st system with minimum cost of upgrading in the future, but low price is paramount initially.. this is to power a 33' travel trailer, even if just to power the all the 12vdc system and charge the battery. I have found some used Sharp 200w panels used for similar price as 100w Renology panels from HD ($75-$90) for each panel. Looking at the specs (see pics) I see the 200 panels are 36v and say about 8A vs the 100w that are 18v and 5-6A. So my question is are the watts (200 vs 100w) or the amps (8 vs 5) more important to consider? Is the 200w panel really giving 2x the power for the same money Is? Is the higher voltage going to be wasted on a 12v system? I hadn't decided on PWM or MPPT controller yet (yes I know Will preaches MPPT) because I will have such a small system initially. I suppose I would require MPPT with the 200w panels due to voltage mismatch (36v panel output for a 12 v system). I currently have 1 lead acid 180 ah battery (crappy) that cannot run minimal 12v power (fridge and water pump) for 8 hours without dying. Yes I'm looking to upgrade batteries too. But think beer tastes on a tap water budget!! I'm sure I've left off many necessary details. I'll clarify what I can... I'm not even thinking about an inverter yet, but I can dream!! ????
