MisterSandals Participation Medalist Joined Nov 5, 2019 Messages 10,053 Location Silicon Valley Oct 6, 2023 #21 Can you post a pic that shows what the BMS wiring looks like?
T thesillym New Member Joined Aug 15, 2022 Messages 29 Location Omaha, Nebraska Oct 7, 2023 #22 sunshine_eggo said: Have the BMS reported readings been confirmed with a separate meter? Click to expand... Yes, voltage was confirmed with a multimeter.
T thesillym New Member Joined Aug 15, 2022 Messages 29 Location Omaha, Nebraska Oct 7, 2023 #23 HLDMYBR said: bad crimp on that balance lead? Click to expand... Might have been a bad connection. I used wire connectors like the ones pictured. On the battery side, the wire is factory soldered. The new JK bms shows normal resistance in all the balance leads. Attachments IMG_1141.jpeg 219 KB · Views: 10
Pierre Somewhere down South Joined Dec 21, 2019 Messages 1,130 Oct 7, 2023 #24 So is the problem sorted now ? Otherwise replace that one cell.
T thesillym New Member Joined Aug 15, 2022 Messages 29 Location Omaha, Nebraska Oct 8, 2023 #25 Pierre said: So is the problem sorted now ? Otherwise replace that one cell. Click to expand... Everything seems to be working normally now with the new JK bms. ?
Pierre Somewhere down South Joined Dec 21, 2019 Messages 1,130 Oct 8, 2023 #26 thesillym said: Everything seems to be working normally now with the new JK bms. ? Click to expand... Glad for you. Strange about the JBD . I use them in all my projects and never had a failure. There is always a 1st time though ?
