Smithalpha
- Sep 19, 2022
- 15
I have a OOYCYOO charge controller supposed to be rated for 100 amp.
Little back around, I have 4- 230 watt panels at 24 volt. I’m using them through the charge controller to charge 2- 8d deep cycle lead acid battery’s.
While the systems being used or while it’s in stand by. The max amperage the indicator on my charge controller is showing is around 15 amps. That seems low to me.
I’m debating if this is a issue with the charge controller?
Maybe a issue with my panels as they are used?
I should say I’m not running the inverter power from the charge controller, it’s drawing directly
From the battery.
I’m not sure if that makes a difference?
Let me know what you guys think.
From the battery.
