NanoVNA
Now all you need is to run inverse FFT, determine location of discontinuity from the S11 frequency response.
And by the way, obtaining time (location) domain TDR data from a swept frequency instrument like VNA is limited by the lowest frequency used.
I was provided with 20 GHz Keysight VNA having TDR software. The calibration wizard set it to operate from 20 MHz to 20 GHz (couldn't figure out how to start at 300 kHz). I used it to measure pulse-forming networks (shorted stubs that convert a fast step into a short pulse). The results it showed (zero ohms series resistance at low frequency) didn't match the components I saw by inspection (thru-hole resistor in series from input to output of DUT.)
I repeated the measurement with an actual TDR from Tektronix, which did show the resistor.
Time domain analysis is useful for impedance measurement and for evaluating a device problem. Learn how to apply the time domain display with network analyzers.
www.keysight.com
The math only works as good as the data provided.
Interpolation is usually more reliable than extrapolation.
EM waves propagate at 3 x 10^8 m/s, 12" per ns in air or free space.
In a typical plastic dielectric, relative dielectric constant of 4, propagation is slowed by sqrt(4) = 2, for 6" per nanosecond.
The 50 kHz NanoVNA has 20,000 ns maximum period, so can resolve up to 10,000' round trip, 5000' one-way. Just under a mile.
So it would work for you home wiring, probably show you all the utility drops to neighbor's houses up to a transformer a mile away. But anything over a mile would alias back into the < 1 mile range. Loss in the wire, more so in the dielectric, would cause more distant reflections to be attenuated, so at some point they could be distinguished or just wouldn't be seen.
