Deustheorem
- Jan 1, 2021
- 14
We are using a Orion 24/12-70 to step down to 12v from our Eg4-lifepower 24v battery.
The problem is everything works fine for hours or days and then the BMS will stop power. If we disconnect the Orion the system comes back up as normal. If you leave the Orion connected it will continue to fail.
But if you leave the Neg leg attached for a while then reconnect the positive lead to the Orion it will start functioning properly.
It seems like it is building up a resistance.
Looking for any possible insights to this issue before I warranty replace it.
I have a 50amp breaker on the 24v side and will have a 90amp on the 12v side shortly.
