iwasforcedtopickausername
- Oct 13, 2022
- 41
Hi everyone,
I have two solar systems at the moment.
One is 4x 100 watt mono Renogy solar panels in series, with maybe 90~ feet of 4 gauge aluminium wire going into a Renogy 60A MPPT charge controller. It's feeding a 100AH SOK 12V battery. I'm getting something like 0.1A with it. And the battery is not charged -- I turned on a load and the power did not go up. Panel voltages are in the 40-50V range. On a sunny day, usually about 88V and I've seen it pull well over 200 watts on a sunny day, not even in the summer.
Another is 1x 50 watt mono Renogy panel with the 20 foot long aluminum (10? gauge) cables it comes with. It's feeding a 10A rated Renogy PWM charge controller. With a load on it, it was saying 0.2 amps coming in. It's feeding an old flooded lead acid car battery (just for powering lights in the barn).
Both arrays are roughly at a 45 degree angle.
It's very overcast and sleeting outside right now.
Could anyone suggest why the 400 watt system is making about half the power, under similar circumstances? I know MPPTs get less efficient when the voltage is way above the battery voltage, but I'd still expect to be making at least twice the power of the 50 watt setup, even with losses. I know the MPPT controller also has more idle current draw (I think 2 watts), so that may be part of it, but I don't think it's the full story.
Appreciate any insights you can offer.
Thank you!
Thank you!
