mikefitz
Solar Wizard
- May 28, 2020
- 2,984
The PCB is only designed to take 2 each side of the metal connection pointsit looks like two terminals, not three.
I am far from being an expert on this. I use AWG calculators found on the internet and read what others are using. I have Overkill's 24 volt 100 Amp BMS and Steve assured me using the 10 AWG default wire would be fine and there are only 2 wires instead of 3. He did suggest attaching the BMS wires to a terminal and using a larger AWG from there but I already knew that. I was only concerned about 10 AWG being too light because combined with two wires is 7 AWG.Thanks! Which leads to the ampacity of 5 AWG (or whichever you are using) - which led me to this chart on a car stereo installation forum - should apply here, too?
