C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #1 What am I missing I can not change the protocol on this Pace bms I tried different versions of software any suggestions
S Spunky Solar Enthusiast Joined May 14, 2022 Messages 161 Location Mid-Michigan Mar 16, 2024 #2 Is that a 100A BMS with 280Ah cells?
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #3 Yes it works well max current limited with the bms to 100 amps and 160 amp fuses on the power out.
S Spunky Solar Enthusiast Joined May 14, 2022 Messages 161 Location Mid-Michigan Mar 16, 2024 #4 I've got a few PACE BMSes, I just don't remember needing to change that. I can check my newest ones as I haven't put them in a network yet.
S Spunky Solar Enthusiast Joined May 14, 2022 Messages 161 Location Mid-Michigan Mar 16, 2024 #5 It might be your software, there were two different ones.
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #6 I have tried many different BMS software packages and no luck. What do you have.
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #7 Not all the packages have the option to change the protocol on the Bms
S Spunky Solar Enthusiast Joined May 14, 2022 Messages 161 Location Mid-Michigan Mar 16, 2024 #8 Have you seen this video? Off-Grid Garage DriveLink This is the one I'm using.
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #9 Have this software but no joy in getting it to work.
S Spunky Solar Enthusiast Joined May 14, 2022 Messages 161 Location Mid-Michigan Mar 16, 2024 #10 As in, won't run on your PC or won't connect through RS232 ?
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #11 Connects with Rs 232 I can do any change but the protocol setting
S Spunky Solar Enthusiast Joined May 14, 2022 Messages 161 Location Mid-Michigan Mar 16, 2024 #12 True that, it won't read my 100A BMSes
S Spunky Solar Enthusiast Joined May 14, 2022 Messages 161 Location Mid-Michigan Mar 16, 2024 #14 Earlier on, there were two versions. One was for changing the protocols, Andy may have a link for Jakiper batteries?
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #15 Very frustrating as Pace does not answer or even respond to any communication with them.
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #16 I will look at Andy's video's
S Spunky Solar Enthusiast Joined May 14, 2022 Messages 161 Location Mid-Michigan Mar 16, 2024 #17 I'm checking an old laptop, found this. But I don't think this is the one. Attachments image (2).png 76.2 KB · Views: 11 Last edited: Mar 16, 2024
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #18 Is it possible to mail to me please. cjels@hotmail.co.za
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #19 I am sitting and scratching in andy archives.
C CJE New Member Joined Jan 12, 2024 Messages 12 Location gauteng Mar 16, 2024 #20 Thank you for the interest in my problem I found the software
