Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,810
A Victron rep told me on a Youtube video that wiring your panels for the highest overall voltage nets you the best overall efficiency. The reason being that charging starts earlier in the day. I have a charge controller with a 150V input limit and my panels are 3 series at 44.4 volts for 135 volts input.
Guys on Solarpaneltalk said that keeping the panel voltage as close to battery voltage as possible nets you better efficiency.
Is the charge controller more efficient with less of a voltage difference because the fets won't have to switch as much? Is that the reasoning or is it something else? And why the conflict between what they are saying and what the victron rep is saying?
Anyone else experience this? If I rewired the system so that each panel fed the charge controller individually, would I see any gains in output due to increased CC efficiency?
