So if you truly stay between the knees, running from about 3.1 to 3.5 volts there should be no issues correct?
I would like to parallel my 60ah DIY Fortune with my 100ah GYLL.
I can set my Schneider CSW 4048 to step in and charge if the batteries drop below 49.6 v so no need for LVD unless the grid is down for days. At that point I could add a generator to the setup.
Charge and discharge are usually around 0.2C.
