Hi,
I purchased two Growatt SPF 3000 24v inverters maybe year and a half ago, and they have been working great I had them setup working seperate from each other.. I finally got around to rewiring, and set them up in parallel, followed the manual thru installation and commissioning. They were working until the second day when I had no solar input. Shut down the units, and restarted and they found the solar input. Worked for a day, and then today the sun came up and the solar was not on line. Shut down and restart and they found the solar input.
Please advise where I should look, I followed the setup as indicated in the manual, they come up as master and slave, I verified all the settings are identical. Here are my settings:
1 - SBU
2 - 65
3 - UPS
4 - Disabled
5 - USE
6 - Enabled
7 - Enabled
8 - 120
9 - 60
10 - 2
11 - 20
12 - 23
13 - 27
14 - CSO
15 - OFF
16 - OFF
17 - OFF
18 - Enabled
19 - 27.4
20 - 27.4
21 - 22
22 - Disabled
UPDATE: Today, again no solar input, but the view screen showed the little solar panel, but it was not charging. So this time i cycled the "Master" unit off then back on (not removing the solar input or battery), and the units's started charging from the solar.
Sunny Florida
1 - SBU
2 - 65
3 - UPS
4 - Disabled
5 - USE
6 - Enabled
7 - Enabled
8 - 120
9 - 60
10 - 2
11 - 20
12 - 23
13 - 27
14 - CSO
15 - OFF
16 - OFF
17 - OFF
18 - Enabled
19 - 27.4
20 - 27.4
21 - 22
22 - Disabled
Sunny Florida
