Rednecktek
Expert Newbie
The box there in the diagram will be where all the batteries come together and is hopefully only a foot or less from the batteries thenselves, so basically the same thing. Everything "south" of that box will be the fatter wire runs.Why not just run the batteries together instead of separate runs? Pos on one to the neg of other so all power flows through it, ditch the 4awg and put in 2/0 then everything's limited to same wiring and fuses. Which 200a for 2/0 is very high and if you're upping to 250a you should be running 4/0.
The wires from the batteries out to the control box will have to be 4awg because that's the size of the terminal holes on the breaker I'm planning to use. Stupid physics.
Positive to negative would give me 24v and that would make my 12v stuff very angry.
