Brewman
- May 16, 2020
- 511
So 150A it is.2000 ac watts / .85 conversion efficiency / 24 volts low cutoff + 20 dc amps / .8 fuse headroom = 147.549019608 fuse amps
The over current protection device is meant to protect the wire.When it comes to the main fuse, it has to be able to handle the inverter and buck converter. As per the manual for the inverter it says 100A, the converter is 12V 40A out so that becomes 24V 20A in. Total is 120A, Should I up my main fuse to 150A or is 125A fine.
As for the PV circuit breakers, I should lower them from 40A to something like 20A. If the array is not big enough for really needing the breakers can I just leave the 40's as disconnects and if the array gets larger then resize them if needed?
On the DC domain, are you sure about 125 amp fuse on 4 awg THNN? (see note below)Well if no one sees anymore issues I'll start putting it together tonight.
On the converter, it's 40A out at 12V, wouldn't that be 20A in at 24V??
Ah! Didn't know which side the 40 applied to!On the converter, it's 40A out at 12V, wouldn't that be 20A in at 24V??
The bms is only rated for 100 amps.My BMS is coming with two 8Awg wires, combined that's 5Awg, should I change that to no wires so I can add my own at the proper AWG?
Ok, 30A fuse. I was going by Wills setup.Plus conversion factor.
40 amps /.9 conversion factor * .5 step down factor / .8 fuse headroom = 27.777777778 fuse amps
I'm not forgetting that UL says THNN can be 105°C when can be used for appliances. Just not 100% sure when it does and doesn't meet the spec.
Update: Found the spec, it's what it sounds like... for wiring on the inside of an appliance.
That is pushing it for 12 awg wire.Ok, 30A fuse. I was going by Wills setup.
It's what the converter comes with. 12 in 10 out.That is pushing it for 12 awg wire.
Yep and those converters are cheap and cheerful.It's what the converter comes with. 12 in 10 out.
