D
Deleted member 102312
Guest
Hello, all. I'm in the las Vegas Area, actually not too far from Will!
But for whatever reason I'm having trouble finding the help I need.
What I need is, someone familiar with going up on the roof and installing the solar panels! I can't do that kind of work anymore!
I'm building a meter zero setup with a Sol-Ark 15, 30-36 panels totalling around 16.5 KW and (will change values as I find out how much I need) start out with 10.x KWH of Trophy Batteries. I will put 10 panels on my flat roof over the garage, and 20+ panels on the west facing 17 degree house roof.
Seems like everyone around here wants me to install a meter collar! They can't believe the output of the inverter feeds the load center! "This is out of my comfort zone", one local contractor stated.
Anyhow, I just need the labor. You would have no responsibilities of my system, working or not. I will supply all of the parts. I will accept suggestions for the mounts, I'm OK with 'ballasted', screwed in, or whatever you think. I will reward your creativity where warranted.
My deliverable needs are: (3) PV Circuits, what the Sol-Ark needs, (6.5 KW x 3) down an EMT to the garage. I also need a 'tap' into one of those (3) circuits of just (3) panels, around 120 volts at 1.5 or so KW, separate wires, down an EMT on the opposite side of the house. I would turn off that one circuit to the Sol-Ark, and power the Rapid Shutdown of the separate circuit separately (lol)!
So, please! Can you help me out? I attached a picture of my proposed panel placement.
Thank you so much.
Penny the Bonded Neutral and John the Wild Leg
Thank you so much.
