I dont understand what you are asking me about routing hot only to solar.even after the wiring was correctly changed to 120V, the pump would not start. Turns out that the float was controlled by a contactor with a 220V coil. once I replaced it with a 2 pole 120V contactor, it works fine. Now I want to power it with the off grid solar circuit, while keeping the float control intact. can i just reroute the black [hot] wire to the solar system, and keep the neutral wire as is? The solar system is stand alone.
