Power measurement on LUX/EG4 6000xp
rnehrboss
Nebraska
I'm testing new 6000xp inverter. Tied to 4 LifePO4 12v 280ah. Batteries connected in serial for 48v (no communications). As has been discussed in other threads, I set the battery type on the inverter to lead acid (Is that why the percentage read 82% full in this snapshot when the batteries reported 100%?)
Question: Inverter says I'm pulling about 20 watts continually. If I look at the BMS on each, they read about 12-19 Watts each. Here is one of the batteries show 15 watts. Also batteries now show 82% which means I've used 18% for 0.9kw (in the battery discharge above). Doesn't this mean I'm only looking at getting .9kw/.18%=5kw out of the batteries when I should be getting 280ah*12*4=13440?
Thanks
Yep. The inverter has no way to know the SOC reported by the BMS unless you set up BMS comms.
Which is cheap but can be easy or not depends on your BMS make, BTW.
Highly likely your BMS SOC counter is not calibrated fully.
I'd give it few more charge-discharge cycles and see what happens.
I imagine the battery voltage indicated on the inverter is accurate (which shows 81%)? That alligns with this SOC table:
53.6 V is ~99% for any 16S LFP.
The inverter is in Lead Acid mode anyways. Wait till you see it reporting 70% at 51.2V
how woud you run discharge. high draw like space heater, or low draw?
Depends on the cells and the connection wire used plus connection quality.
For LFP, you are very safe until 0.5 C .
This wouldf be 140 Amps. More than enough to run entire house at once on 48V.
Your 6000XP is the bottleneck here, not batteries.
Thanks
As pointed out by shvm, without BMS communications, the inverter cannot determine the State of Charge reported by the BMS and will charge/discharge base off the voltage reading.
So I have an 6000xp with a bank Lifepo4 batteries that doesn't offer communications. The Leadacid workaround is okay but I'm curious. The 6000XP knows how much is being charged and discharged. Why can't it keep track of SOC? I have a shunt on the batteries and it can do it just by keep track of how many amps go in and out. Why can't the 6000XP do this and offer a more helpful guess as to a percent of battery left? A DIY lifepo4 mode.
Unless there is such a mode and I missed it?
That's an excellent question, and I'll be forwarding it to our engineering team for consideration to more accurately predict SOC when in Lead-Acid mode.
Jared, I noticed this error too. When will a new firmware update fix this?
