Rednecktek
Solar Wizard
Nope, that's an 8s for 24v batteries. You need a 4s.
A 1500w cooker would make things easier for sure.
You're fine, you've got the basic idea down and your numbers are close enough. Don't panic.I'm not good with understanding the ah and converting.
Combining 4 would then give me a 12.8V system, and 3865Wh, that was my thought process, but that reflects to 300ah right?
Thats okay.
Easier? Yes, maybe. As fun? Not even close!Your life will be a lot easier if you purchase pre-made Li batteries.
I guess I have to agree with you. A 300ah done DIY would cost me roughly 700 usd, an equivalent 300ah (the cheapest I can find) is 640 usd.Your life will be a lot easier if you purchase pre-made Li batteries.
The savings of home built vs buying a commercial battery are not as significant as they once were.
The biggest mistake most people make in building a power station, including the commercial offerings, is far to low of battery capacity. As an example, your original post would need something more like 4 x 100 amp-hr @12 volt equivalent to work reliably. That is approaching 75 - 100 kg by the time it is all in the box.
Yes, but look at how much you are learning just by doing the research - it is a lot.
The renogy rovers are an exceptionally poor mppt charge controller. The reason is that they have very high standby power draw - even at night, and the real world operation does not match the manual very well. Also if your battery ever goes low and trips the BMS, the rover cannot recover it, as it pulls it's operating power from the battery - not from the sun.
I built my portable power station using a bogart engineering PWM solar controller and the monitoring, but victron also makes nice controllers.
I am a fan of 24 volt systems if you can swing it.
A lot of DC refrigerators come in 24 volt or dual 12 / 24 volt.
USB ports are similar - many will run on 12 or 24 volt.
Nope, a 2000w 24v inverter will output the same 2000w of 120/240v power.So If i'm lets say building a 24v system:
a 100ah 12 volt, is equivalent to 50ah.
Any "changes" looking for 2000w inverters? a 2000w 12v system is 2000w 24v system, all the same?
(sorry, this is childs play for you guys, I apologize!)
Spent like 6h of researching and looking prices and making a list, but then I was just like - again, what are my needs
Those do indeed work wonderfully, I've cooked a crap ton with mine.Works good. And fast.
