I'm trying to get to grips with LFP batteries and thought I could dip my toe in the water by installing a small pack to power my trolling motor.
I'm going to use the motor on a small tender, and would be quite happy with a full throttle duration of 20-30min- it''s just for getting to and from a mooring. The motor draws 64A at full power, so I reckon any battery over 20Ah will be big enough for me. I'll be taking it ashore, or aboard the yacht, to charge. Small and light is good- as is cheap, obviously!
There are plenty of 'drop in' type batteries on eBay at low prices, but it is the BMS which lets them down, with maximum discharge currents of 1C. So I would need a 64Ah battery, which is overkill.
Daft newbie question no 1: what if I took power directly from the cells, bypassing the inbuilt BMS? Could I still charge via the BMS, or would that not work? (Yes I know in this scenario there is no automatic low voltage cut off).
Question 2: I could buy a bare pack of balanced cells, no BMS, and draw power directly as above. Does the lack of BMS make charging it more difficult?
Thanks in advance
Thanks in advance
