I have had the EG4 3000 off grid for about a year with roughly 2k in 100 watt panels. I have always had a problem with voltage dropping quite a bit when it first starts converting power into Watts for the battery when PV first being turned on. Basically when i first turn on the PV through a breaker I might have 200 volts, the unit takes about 10-15 seconds to get up to full watts but by then it drops the voltage about 10%. I cannot find out anywhere if that is normal and I can only tell you that Signature Solar where I bought it is the most uninformed nightmare of customer service I have ever encountered. I would love to know how much your drop is.
So I recently bought 14 535W Canadian Solar Bi-facial. In trying to test them I currently had 10 100w panels left on my roof hooked to the system in series. According to the online calculators those 10 100W Panels would work near perfect with 5 of the new ones. A .053% loss for 3570 volts or so. Problem was after testing the 535W panels at near perfect test angle at about 560W each I placed 5 in series and ran them in parallel to the 100W set and could not get over about 2.5KW to 2.6KW so I switched to just the new panels and started adding more and could not get above 2.6KW until today with 8 panels and a swap of the input wired to the inverter I got as high as 2.7KW. I think they might have been aluminum sold as tinned copper, (go figure). So during today's testing I was up to 11 amps of the 13rated amps at 5 panels but on adding number 6 or forward it started dropping, This number seems to be what is keeping me from going about 2.6KW to 2.7 KW, that and the dropping voltage combined which seems to be 10 to 15% after it starts converting. What in the world is making the amps drop keeping me from getting above that number? Each panel tests at least 100% rated voltage, watts and amps until strung together into that inverter.
Any ideas? With my thermal camera I see no wires getting warmer than the 10 degree F increase that made me swap the PV input wires hoping that was the issue. I am at a loss.... I called SS thinking the inverter was bad, they sold me a refurb last year, weirder things have happened. I knew I was getting no where with them when they told me after an hour of talking to higher ups that my issue was that even though the EG$ 3000 off grid is rated for 5000W input it could only do that for a couple of seconds that it was only really rated at 3K PV input not the advertised 5k. It took me a long while to convince the rep that the info they were given was 100% wrong and that at best they were misreading the inverter output limitations.
