Pylontech battery not showing charge level.
simonstroud
UK
Not sure of this is an issue, a configuration problem or normal behaviour.
I have 3x pylontech batteries, 2 show charge status leds, one doesn't. They all show a flashing run status led and no alarms.
System appears to be otherwise running normally.
When my inverter is reporting 100% charge, shouldnt all 3 batteries have all their charge LEDs lit?
Hi
Try connecting the Can bus interface to the 3000C since it will be the master in your case. Connect the two 3000C without the 2000C and notice the status. Then you can connect 2000c and observe the behavior of the three Pylontec's. Also check the firmware versions if it is compatible on the batteries. If you do find the problem, please share on forum. Thanks
