omaigadlol
- Sep 27, 2022
- 11
That's the plan. We'll see how it matches with reality. I have one spot on the property that gets sun on 21 December and it's on a south facing hill just to the north of a thousand foot bluff. On the other side of the bluff is ocean. So the slope keeps trees from shading the horizon and then it drops off to the water. There are about nine small trees I will cut (and use for lumber) and then it will see the sun directly for the full four hours if it's sunny. Directly south facing ground array, one axis angle so I can tilt panels up but will be straight up and down (6 degrees from optimum--although I will set them to 6 degrees and if snow isn't an issue just leave them there) during winter to keep snow off.
The batteries will be stored six feet underground in a culvert with an insulated roof/floor and shed over top (shed and floor not shown). Two rows of panels. South facing row is down slope to prevent it from shading the north row of panels.
Looking down into the culvert you can see where the Pylontech batteries will go through the wall and I'll have a door to access behind the wall. I will heavily insulate the batteries to ensure they stay at least 65F year round. Doing it this way allows for shorter cable runs from the front of the batteries to the other components. So hopefully the insulated batteries inside an insulated culvert underground will ensure 65F even when it's -4F outside. If that doesn't work, I'll look into heating pads.
And after going through all this effort and spending the money on the PV and the SCC to harness as much as I can during that four hours, I'm going to be very bummed if the Pylontech BMS throttles me. I guess we'll see.
This will be fun to see in the middle of a forest in Alaska in the middle of nowhere. A helicopter will deliver the panels up there once the snow melts.
Edit: Actually it looks like I'll only get 3 hours of sun on 21 December. So very important that these batteries take whatever charge they are given.
Hi, how'd you overlap the stuff in the last picture?
