Rednecktek
Solar Wizard
Common misconception. It's for hooking batteries up to bus bars or terminals, each side needs to be the same length. I.E. if the positive wire of your furthest battery is 22" from the connection point, then all the positive wires should be 22". If the negative is 30" away then all the negative wires should be 30". Your positives don't have to be 30" just because the negatives are.I have another question: Is it true that both the positive and negative wires going from the inverter to the battery must be exactly the same length?
In practice it usually ends up that all your wires are the same length just because of where the battery terminals are physically in relation and if you're cutting a bunch of wires it's easy to just cut them all to the same length at the same time.
