That won't work. The two MPPT's will fight for control over the circuit.
And neither will produce very well.
I was wanting to try, since it's two unalike mppts one with an operating voltage a lot lower than the mini split mppt. Figured it might reach a equilibrium around the min volt of the mini split mppt since the battery mppt can pull lower than the mini split. And I would rather the batteries have priority over the mini split anyways.
Not sure if it'll work but I'll find out lol
That is exactly what you are describing.
Its not what I mean, in the NEC a grounded conductor is any current carrying conductor that has a bond to the grounding conductor. Eg a neutral in a normal AC system.
There will be no current flowing through grounding conductor. I just don't want my batteries and 48v equipment that are somewhat in the open to have a negative connected to a 150v system without any ground bond on that negative. If there was a L-G fault on the PV side that would energize the negative of the batteries and other 48v equipment to the negative PV voltage without causing any fault current to shunt the voltage/trip a breaker, the only notice of the fault would be if you probed from the negative to ground.
A summery of the wires going to the mini split:
Green, grounding conductor.
White, 120vac grounded conductor.
Black, 120vac ungrounded conductor.
White marked with black, PV grounded conductor (negative).
Red, PV ungrounded conductor (positive).
I also mesured voltages on the PV input to the mini split while it was running, and I didn't see any voltage to anywhere. Unlike my EG4 48-3000 that has a transient voltage around 300vdc from either + or - terminal to a ground refrence.
