Cmiller17363
- Jul 24, 2020
- 23
Sorry if this is a dumb question but I’m wondering if you can overpanel an EG4 solar direct mini split. I want to use 2 24000btu units primarily for heat in the winter so I’m trying to overpanel to produce decent heat even on cloudy days. Something like the talesun 400w bifacial panels from signature solar wired 10s2p for about 360voc. The Isc will be 22-24 amps due to parallel strings. Is this an issue? I know most SCC’s can be overpaneled pretty significantly and be happy as a clam but I don’t know about the mini splits.
I’m deliberating the chiko car port as a pergola and wiring direct to 2 of the 24000btu mini splits.
Suggestions including respectful criticism welcome!
