Badgerz
- Jul 9, 2022
- 27
1st let me say on the resource that Will Prowse started here, Will has performed "Yeoman Service" here due to his general enthusiasm and his experience with this and other technologies. Thank you.
Comments:
My dealing with solar related manufacturers, marketing and documentation that go along with them correlates with my over 40 year experience with technology manufacturers, tech support and suppliers in general. The trend is less and inaccurate documentation, exaggeration of capabilities, promises of future improvements, longer waits for tech support , and the language barrier ect. It is what it is.
Some of my experiences in the DIY solar area:
The misunderstanding of Low and High frequency inverters. I "thought" i researched sufficiently the purchase of a Low Frequency inverter, For me it was down to Sigineer M6048D and MPP LVX6048, i chose the LVX6048 due to the higher solar voltage input (450 vs 250), turns out the LVX6048 is a high frequency inverter with an auto transformer. all marketing materials seemed to indicate low frequency. after purchase and contacting contacting tech support for this unit it was stated "The surge capacity on all our inverters is 2X for 5 sec, but this is the result of testing with “resistive load” in the laboratory. Therefore, we always advise the customer to only use “the nominal maximum continuous power” referring to the inverter, which is 6000W in this case. It’s the best way to avoid the risk of overloading your inverter." I wanted a Low frequency inverter that could handle at least 15KW surge load. Another issue with this inverter - parallel mode, I was preparing to connect 2 of these units in parallel however looking at others and their experiences, i am hesitant to do so now, just look at the threads on the topic. Any comments on parallel experience with the MPP LVX6048 is welcome.
Another experience is with Seplos BMS , stated on the distributor web site it has "heater function", after installing these units and attempting to use this feature i was informed by the distributor that the "heater function is a future feature not yet available". I chose this BMS for the heater function which was plainly on the distributor site and still is. so there you go.
Another issue is Integration, specifically between inverters and BMS , my experience integrating other systems specifically PBX phone systems and Property Management systems via RS232, its not easy sometimes for the 2 systems to talk with each other, they need to have "common language" and different manufacturers have different ideas on what they want and don't want to see come across the link. In a conversation with a battery supplier recommended on this site, his statement was "the battery system has an interface but does not recommend using it" I personally cant see the real need to have the inverter and BMS talk to each other, given the risks, because think about it "what could go wrong????"
Talking with someone who has years of experience with inverters and MPPT, his comment was that " most of the failures and problems come from Surges, overloads, sudden interruption of feed or loads or heavy loads in general". given that manufacturers are not completely honest with the specs and/or they dont apply to the real world, i wouldn't go the the rated capacity so make sure you have plenty of headroom for anticipated surges, and don't disconnect under heavy loads. ect
I would NOT recommend generally that people install a system unless they have experience with electrical, electronics and common sense and are VERY careful and focused. one small mistake can destroy components and this stuff is Dangerous and LETHAL !!! Have someone install it who knows what they are doing, let them take the risk and danger if you can afford it.
Questions:
Anyone know of a AFCI or AFCI/GFCI arc-fault interrupt for the panel side that operates at approx 500vdc and 20 amps? I searched and really cant seem to find any, i am not referring to disconnects, although if one does both i would be interested in those. i have 40 used panels from SanTan solar in Arizona which i want to make sure have good protection from arc-faults due to age (still a great deal for the watts).
Anyone have a FIRM grasp on grounding and lightning protection? I have one inverter 300 feet away from the 240 main service, 10 feet away from the panels and 20 feet away from a 450 foot deep well with steel casing which the submerged pump is connected to the 240 output of the inverter. How would you do it? any suggestions?
another inverter is inside a CON-EX approx 150' from the house/main 240 service which is connected to the inverter input, 20' from the panels running at around 300vdc, and output approx 150' back to the house on a sub panel feeding certain circuits within the house. any suggestions?
I used to think grounding was easy. i was informed by a surge suppressor manufacturer in Florida some years ago, lightning can come back up the ground to get into equipment and that the ground should also be protected which they sold a low voltage protector (Phone line) that protected the ground from being used to come back into the system PBX.
For future reference does anyone have experience on lightning damage and what is common and gets the most damage? I am not talking about direct hits, more like close with static build ups/discharges? Do panels take alot of damage? ect.
Anyone know the proper fuse holder for the VICfuse included with the MPP LVX6048? even went to the mfg site and couldn't find the fuse holder for that fuse
Of course if we want the best equipment and the best and accurate documentation we have to pay more, a lot more. This is why this forum is such a wonderful resource for the capable and experienced DIY crowd, who either just like to "tinker", probably OCD, maybe a bit on the autistic spectrum, cannot afford the best or some sort of combination of those.
Through this "hive mind" we can learn from others who have experience with this line of equipment , manufacturers and dealers.
Thank you
Comments:
Questions:
Thank you
